Trim Guage
oldboatguy
I Am Installing A Trim Guage On My 1984 70 Hp Evinrude
And I Want To Know If The Main Wiring Harnes Carries A Wire
From The Trim Sending Unit To The Control Box And If So What
Color Is The Wire. Is The Wiring There Even If No Guage Is Present?
HighTrim
Re: Trim Guage
You will generally have 2 wires on the sender, a brown with white stripe which goes to the gauge sender terminal, and black to ground. The gauge will also have a ground, a blue wire for the light, and a purple wire going to the ignition switch. You will need a model specific gauge, 1 ohm for up and 88 ohms for down. This may help.
http://ww2.tflx.com/pdf/trimsy~1.pdf
Gary H NC
Re: Trim Guage
HT you are faster than an OEM service manual....:D Good Info!!
HighTrim
Re: Trim Guage
Lol Gary, after selling off most of my Harem of boat/motors, have alot of time on my hands now ;)
Currently on the hunt for a 90's 18 to 20 ft cuddy and (possibly) an older wooden boat for restoration that I would like to put a Javelin on. Just have to get the ok from the boss/accountant (wife). :)
I think I would look pretty good in this old wreck! Hopefully Ill be picking the brains of the 50's vintage guru's in the near future.
Gary H NC
Re: Trim Guage
Man HT that is one sweet boat! It has your name written all over it!:D
oldboatguy
Re: Trim Guage
Thanks For The Info,
One More Question
Where Would Be The Best Place To Acces These Wires
Are They In The Main From The Motor Or In A Seperate Harness
That Carries The Wires To The Trim Motor..
The Bundle Coming From The Trim Motor Has 5 Wires Two That Plug
Into The Trim Switch On The Control Box And 2 That Are Loose
A Black And A White One What Are These
