Trim Harness Clamp
lmannyr
Don't ask me how but I lost the plate that holds the trim wires to the transome officially called "TRIM HARNESS CLAMP" in the #6 Mercruiser Manual.
I looked online for this piece and have been unsuccsessful. Anyone have a part number (OEM or Aftermarket)? Or know where I can get it.
PS...I think I trashed the piece when I removed the old wires out.....last week.:(
Thanks!!!
Don S
Re: Trim Harness Clamp
What page and figure number (if any) in the manual?
lmannyr
Manual #6 Page 4A-6.
It's the plate with two bolts that hold the trim wires behind the gimbal ring and above the drive bellows.
Don S
57322T is the part number, it's called a cover in the parts catalog.
lmannyr
I saw that one but wasn't sure cause of the different name. Thanks.
Do you use mercruiserparts.com or can you recomend a better place for Illustrated Parts Breakdowns?
thanks for the quick responses!!!
Don S
Personally, I use Mercs dealer program.
lmannyr
NICE!
Wish we consumers had access to that. Anyhow...Thanks AGAIN!!!
muc
"Retired" Association of Marine Technicians...
Might want to use #12078 clamp. It only needs the one lower bolt to hold it in so it is much easier to install. Good Luck Muc
lmannyr
Has anyone done this? Is this recommended? I wouldn't want a leak there because of the ease of installation.
Thanks for the tip muc, hopefully this is doable as the top bolt took me like 4 hours to take out!!!:mad:
Don S
That part number is for a Gen II drive, but the same senders are used and are installed the same way, so it shouldn't be a problem. If you are concerned, just get the right part with 2 bolts, then you don't have to worry.
lmannyr
So the dimensions are the same and will hold just as good? This would make installation & future replacements much easier. Does the top bolt HOLE go through to the inside?
Hopefully some who have done this will chime in.
Luis
