trim help
splitshot
does anybody have a tilt and trim diagram for my 1977 200 evinrude ?? my factory manual shows its supposed to have 3 wires a green, blue, and black but the trim pump only has 2 a green and a blue...my manual shows its supposed to have 3 and be wired into a relay box with 1 relay...but i read on here the 2 wire motors have 2 relays ?? i'm a little confused any help will be greatly appreciated thanks Jason
rsimmons42
Re: trim help
Jason,
Here is a diagram that will work for every model of tilt and trim.
Bring the diagram to the auto parts store and they will give you the correct relays. You will need a momentary on/off/on switch.
many people have posted problems with wiring there TNT and this diagram has been there saving grace, let me know if it works.
http://www.arcomarine.com/xhtml/tech tilt trim motor tips.pdf
