My trim lines need replaced. They disappear into a dark hole in the transom bracket behind the engine. Anyone changed these out without pulling the engine? Boat is a 94 Four Winns Horizon 230 with the 5.8 FI and Cobra SX drive.
Hi, I know you posted this a while back I’m having the same issue and all I find is pulling engine so it’s a relief to see this. Any other info you can share? Same year four wins but a 4.4 literNevermind......Found my answer. Remove drive, remove nut holding trim line manifold, separate manifold from transom bracket by pulling aft thus exposing the two trim line connections I need to get to. Found it in my OMC Cobra Drive and Transom Bracket manual.
