Trim hoses
Jamz33
My friend was going to change out his trim hoses due to one leaking but before he could replace them his house was destroyed by a fire and therefore the hoses burnt up as well. He is dealing with a lot and asked me to go ahead and fix it for him. The problem is I don’t have anything to go off of as to what the hoses looked like, or fitting size, or anything like that. It is a 1988 mercury black max 150 and I have found some online, but want to make sure I have the right ones. I have pictures I can post if needed. Does anyone have a link to where I can get these? Thanks.
merc850
I thought the 1988 models used an integral trim pump/cylinder design which I see online, the hose models were from 1966-1976, maybe you should post a picture.
Jamz33
merc850
Ok you got me, I would suggest contacting a dealer with the part nr. and see what they have.
Somebody here might jump in.
Faztbullet
Tis a 1983 model, needs all 4 hose and the tilt limit bolt as it bottoming out on cylinder
Dukedog
if ya have a hydraulic shop anywhere close would be easier and probably cheaper ta drag it down there and have 'em made.....
