62cruiserinc
- Joined
- Oct 30, 2009
- 294
I have a 1981 Sea Ray 260. The trim up/dn has always worked fine.
Yesterday I went to raise the outdrive (Alpha one) and it worked. When I went to lower it (I just finished replacing the impeller) it would only lower about half way. Also, I heard a pop somewhere from the outdrive area (I was ion the boat).
I disconnected the hydraulic cylinders from the outdrive. There is no binding in the outdrive itself, I can move it easily the full range by hand.
The cylinders will extend fully but only retract about 1/3 of the way. The motor runs in both directions.
I checked the fluid level (this is an older unit that doesn't have the see-through reservoir) and it looked low looking down the hole where the fill plug goes. There was some fluid on a fitting which I tightened. I filled it up to the bottom of the threads of the fill plug.
Now the starboard side cylinder wont retract at all, and the port side retracts about an inch.
Any ideas on what I should look at next? I don't see any visible leaks anywhere. Do I need to do some bleeding? Did a cylinder fail and cause both to act incorrectly?
I can't find much info on the net on this unit. Does the solenoid on the side of the unit actuate the up direction?
Thanks
Steve
Thanks
Steve
