series60
- Joined
- Jan 4, 2010
- 420
I'm back at the original issue I have with porpoising. My 1984 Mercruiser 305 powered 20' IMP likes to porpoise above 25mph. Shifting weight doesn't help. It improves when I use the tabs but I feel it would improve more if I could get the trim rams to retract completely. If I disconnect the rams the outdrive will drop at least another 3/4 inch. My thinking is if I could get the rams all the way in/down the porpoising would improve. Now I have to state that this ole' girl has been completely rebuilt bow eye to stern including new transom. The outdrive is a combination of newer upper housing (Upper housing 1.32R #OB568855 (Alpha One 0A479507 -> 0D469858 (1986-1990) (not the correct gear ratio but I live with it) and lower is an R model of unknown vintage (assume original 1984). Trim cylinder
ort #98703 Starboard #98704). I have done the gimble ring mod also.
The first question is how much ram shaft extends when they are all the way retracted. Mine measures approx 3?" of exposed ram shaft when retracted. Looking closely I can see old shadowing on the shaft where it at one time might have retracted to about 1?" of exposed shaft.
Second question? Is there an adjustment for retraction length of the rams?
Hope this is to confusing!
