Trim indicator problem
crowbait
Last week or so I posted a thread regarding my trim problem. I cleaned the trim position switch and trim limit switch per advise from another member.
The trim now seems to work just fine. The trim position indicator on the instrument panel will only indicate full up or full down, it zooms between up and down without stopping anywhere in between.
I lubricated the contacts with die electric grease before I closed things up.
I also marked the previous positions with tape so I'm sure the switches are back in the same position as before I started.
Did I use too much die electric grease or should the contacts be dry?
Thanks again,
crowbait
