Trim limit & indicator wires.
jmatteo1
I began the process of disconnecting everything for a coupler replacement yesterday and discovered that the trim wires were a bit frayed, so they will be replaced. They look to be 14 ga. stranded wire. Is there a premade harness replacement or can I made a set from wire purchased locally? Thanks
Laddies
Banned
Re: Trim limit & indicator wires.
The only way the make a proper repair is with the sender kit, the original wires were junk, Mercucy came out with the kit, which includes the senders and new wires to repair the problem, anything else is a waste of time. I have seen a lot of things tryed but they are temperey at best, the kit is a pain to install but the only real fix--Bob
