I recently noticed two frayed wires inside of my boat. The trim gauge has not worked in awhile, so I thought maybe these two wires are for the trim unit (one on each side of the lower unit). In tracing the wires, I noticed that they go from the trim unit in the boat to through the transom. They have bullet ends (in the boat) that connect to a harness, and one of the ends is green, and the other is purple. Trim works fine, but gauge doesn't read...is this why? Also, I assume it's ok to use the boat without these units be operational, right? If so, how low can the motor go while motoring, and will it automatically stop in the highest position before it does any harm?
