trim limiter fuse holder
tbey1584
OK so had a couple projects to do this winter for my boat to be good to go for next year. I redid the trim pump and switched it from the original Yamaha to a more common and cheaper Mercruser. Next question is the trim limiter. I have a 93 Ebbtide. The trim limiter has an inline fuse on it with a cap on the end. I must have lost it somewhere down below, and can't find it. To finish out the season I jerry-rigged a piece of metal to bridge the gap and allow the trim to work. I looked in the service manual and all over but found no answer to where I can get the part. Let me know if you have any solutions or need more info (which I am sure you do)
Thanks for the help
Re: trim limiter fuse holder
Ayuh,... An in-line fuse holder can be bought at ANY auto parts house, 'n probably right here at iboats marine store....
