The OEM trim motor replacement kit (2 wire motor with relays) is 878265A6, but NLA.
I would check ARCO as they make replacement kits for that engine, and for a whole lot cheaper than OEM. Likely you will need to replace the solenoids of your 3 wire motor with the relays and wiring harness for the newer 2 wire motor.
