Re: Trim Motor for 1986 Force 125
My first question is: Does it go in either direction or just one? There are two relays under the cowling, one for up, the other for down. If only one direction is working, you could check there first (on mine, I can swap them) If you think it is the motor, the brushes and a bimetalic relay are located under the cover of the tilt/trim motor. If you are machanically inclined, it is very easy to remove the cover and clean the split ring on the motor. (where the brushes contact it) With the cover off, you can check the bi metalic relay also-make sure it is clean.<br />The Seloc manual has a pretty good set of tests you can perform to rule out other components. <br /><br />Good luck
