liquidlew
- Joined
- Feb 14, 2008
- 304
Ok, I found that I do have a bad solenoid, so I am replacing it. I hooked up the trim motor directly to the battery (solenoid is on order) so I could lower the drive. It works but sounds kinda strange on first contact, it doesn't respond immediately, seems to stumble and kicks in full bore after a second or 2. Same symptoms raising it. Also does it using the switches. It started doing this last time I used the boat last Oct. The motor is less than 2 years old. Is it on its way out or is this normal? It never did this before last Oct. so I'm concerned. If it needs replacing, how long do these things last?
