trim motor woes
the_machine
I just bought a '79 rienell 170 with volvo penta 120b/270d outdrive and it seems the trim motor refuses to bring the outdrive down, it works fine to pull it up, but nothing happens when the "down" lever is pushed.<br />I manually pushed the motor down into place (against hydraulic pressure) and was able to run the boat this way for our first day, has anyone ever experienced this?<br />is this common when trim motor controls fail to perform the "up" but not "down" operation?
wvit100
Re: trim motor woes
Does the motor work when you hit the trim button? Do you hear it spinning? Maybe the switch is bad and the motor is fine.
the_machine
Re: trim motor woes
as it happens, I switched the wire to the power lift (it seems this boat doesnt have "power trim" , sorry, new to boating), and now the same switch lowers but doesnt raise the outdrive, I suspect the culprit may be the three way "return to nuetral) switch itself, I will replace it and report back, thanks for the response
