trim motor
rockyman
1981 165 inline 6 cyl with a merc 165 outdrive , to change the oil lines from the tilt and trim motor to the outdrive , must the drive come off and if not how and where do they connect to the drive . thanks
fishrdan
Re: trim motor
You don't need to remove the outdrive. You need to drop the manifold that is mounted underneath the gimble housing (where the trim ram hoses connect) and then remove/install the hoses. It will be easiest to tie a fish rope onto the old hoses so you can pull the new ones back into position.
Down load Manual #1 in the "Adults Section" for better detail.
