Trim n tilt fixable or replace?
PuddleJumper
My 90 200 trim and tilt motor has been becoming increasingly SLOW both directions. Now it still moves but Barely. Pump/motor is prolly toast. OEM only comes as a unit $900 Aftermarket is $500. Anyone have any luck just replacing brush cage and brushes? Is it hard to do on this model?
Scaaty
Re: Trim n tilt fixable or replace?
I'd pull the motor and check it first, then go from there. Any electric starter shop should be able to rebuild'em
PuddleJumper
That's what I plan to do but was hoping someone had experience with this model as the pump and motor are one unit.
