Trim Pin on 35hp Johnson
AntsGrady
Hi Guys,<br />I need to remove the pin on the transom to adjust the height of the motor but it is majorly seized. Tried rust away and a hammer an chisel. Next step would be to just get a new pin and put in the hole above this one as I want to raise the motor. Any other ideas on how to get this pin out? What is the proper name for this pin? I've been trying to find a new one but don't know the proper terminology. Thanks!!<br />Anthony
Joe Reeves
Re: Trim Pin on 35hp Johnson
You will need to apply heat, using a hand help propane torch to free that rod.<br /><br />The name of that rod is "Reverse Lock Rod".<br /><br />Note that you are not attempting to raise the engine, but rather to change the tilt angle.
AntsGrady
Sounds like a plan Joe. Thanks for the input. I won't be able to try for 2 weeks but when I do I'll let you know. thanks!!!<br />Anthony
Chinewalker
I've had to cut a few of them. Cut it flush with the clamp bracket casting and then either drill or drive the rest of the pin out. A good flat punch and BFH can do wonders. If that doens't work, get a good drill bit and drill it out. New pins aren't expensive, and it's not hard to find used ones...<br />- Scott
AntsGrady
was looking for them last night online but all it kept coming up with was car stuff......i'll have to try again.
Chinewalker
Hi Ants,<br /> Look a little closer to home. Local outboard dealers, shops, graveyards, etc...<br />- Scott
rwcreigh1
i agree with Chinewalker.but dont cut in to the boat.and please if you use a torch(i would try first)remove any gas lines and tanks.good luck
