trim pressure??
wildcat8466
I need to take the hydraulic lines apart from the motor are they under pressure. Do I need to prepare for a mess?
Reel Poor
Re: trim pressure??
Trim the drive all the way down and remove the hoses slowly as there may be some residual pressure. And also prepare for a mess.
HT32BSX115
Re: trim pressure??
No,
There's no pressure unless the pump is running. There could be a little if the drive is up due to the weight of the drive....but that's about it... Some will still "run out" though If you want to call that a mess .......
wildcat8466
Re: trim pressure??
WILL I hAVE TO BLEED THE LINES LIKE BRAKES ON A CAR WHEN I hook them back up. OR WHAT WILL I HAVE TO DO TO GET IT BACK TOGETHER RIGHT
ziggy
Re: trim pressure??
we should probably know what yer working on......
on my old 1 drive, i have to bleed them, on the newer alpha1's there self bleeding, ya just run em up and down 10 times or so and that's it...... don't know if it holds true for yers though, we don't know what it is.....
get an oem service manual.
HT32BSX115
Re: trim pressure??
No. It bleeds during operation.
but only fill the reservoir when the drive is down.
