will trim down but only hear a click when trying to trim up.
Have to manually lift the motor to get to resevoir. Its a plastic container to the right with a large cap midway down. When I open this fluid pours out. I found a hex screw to the left of this container level with the bottom of it. Same thing when I loosen it fluid comes out. Does this mean I don't need fluid or is there somehow pressure on the system with the motor all the way up. When I lower the motor manually two metal rods come out to meet the motor on its way down. Should I check the fluid with the rods out having someone hold the motor in place. Will this relieve pressure? With the motor all the way down I cant get to anything.
Problem started last summer only happening every now and again. Now it seems to be permanent.
Motor is very clean and all connections seem clean
thx
thx
