Re: trim problem
the trim limit switch located on the PORT side of the bell housing is either not set properly or broken
does the trim gauge on the dash work properly?
the trim button will move the drive all the way down, and will trim the drive up through the trim range (about 1/4 up)
the trailer button is used to tilt the drive beyond the trim range up for trailering
download manual #6 from the adults only sticky and look at the trim system info
