trim problems
reilly
I have an 86 force 125 ob the power trim only works when I am on level ground and when I go in reverse the engine kicks up out of the water. It also won't trim up while driving. I've bled the heck out of it any Ideas?
Oldsaltydog
Re: trim problems
The first problem -- is your manual override, if you have one, set properply? Second problem -- do you have a faulty relay?
reilly
Re: trim problems
no manual override no relay thanks for the Idea<br />though
cinder1995
Re: trim problems
I'm having the same problem. I've tried everything. I believe replacing the seals in the cylinders is the next step for me.
tinbender2u
Re: trim problems
mine got water in it will go one way and not other but motor runs so think i need seals too
