trim problems
meallenjr
my trim motor went out so i changed it now the the motor will not raise, the trim tabs will come in and out but will not hold motor up and i can push them back in. everything worked before i put the new motor in what can be wrong?
it is a 1988 88hp johnson
Re: trim problems
Just a thought, but I had that problem with my trim after having the motor rebuilt. I had to loosen off the manual relief screw and when we put it all back together the trim wouldn't work. It sounded like the motor was trying to work but it just didn't have enough pressure to move the motor. We ended up replacing the o-ring that is on the manual relief screw and topped up the fluid. It works great now. Might be something to look at if you had to loosen off the screw while changing your trim motor. Hopefully your solution turns out to be something as simple as mine was. Good luck. Bigfish
