boat4fun83
- Joined
- Oct 19, 2008
- 45
I have a couple questions. My trim down will work and my trailer up will work however trim up will not work. Tilt/Trim gauge does not work either. I purchased new trim limit switch and trim sending unit. Should this fix my problem and is there anything I should watch for while replacing?
Also, I have an oil reservoir bottle that is leaking very very slowly. I filled it to the full line back in october during winterization and it has gone down about a cm or so. Is this something to worry about or would I be okay just adding oil until next year and then getting seals replaced? I'm assuming the upper seals need replaced b/c I cannot see oil leaking anywhere on the outside.
