- Joined
- Jul 18, 2011
- 18,477
Yea, so I installed the outdrive last night and connected the trim rams. Of course, the rams were all the way extended, so I had to lift the outdrive all the way up to connect them.
I went to lower the outdrive and the trim pump ran, but it would not retract the rams. It seems like it wants to go up, but not down. I tried a variety of forceful things on the outdrive, just in case it needed a little persuasion, but no go.
Fluid level is good. I believe the pump is Mercruiser trim pump # 865380A13
So, tonight, I'll check out the electrical connections, etc.
BUT, before I do, I wanted to make sure I understand the workings of the pump, etc. Is it pump motor plus 2 valves/solenoids for raise/lower?
My thinking is that the 'lower' solenoid is not paying attention when I press the down button on the trim switch panel.
Engine specifics are in my sig. below. TIA for any insight on the inner workings of the pump.
