1995 Merc Bravo 2, 5.7.
On one of my drives, I can only get the drive to go up if I remove the "down" hose from the pump itself. Fluid flows freely out of the down line then as the drive goes up. If I leave the down line attached, the pump really seems to bog down, almost like a hydraulic lock, and the drive will not go up with either the trim or trailer button.
Also, when both lines are attached, I cannot get it to go back down with the pump either, despite the fact the pump seems to be running normal. There is a slightly different sound to it though. Removing the "up" line, the weight of the drive is enough to let it back down again.
Not sure if it can be adjusted/repaired, or if I need a new pump.
Thanks,
Thanks,
