Trim pump leaking out from resavoir when pumping normal?
cruiser83
I think my trim pump is leaking from the resavoir when pumping? I just bought it used. But I noticed leaking only when it's pumping. I'm not sure if it's coming from reaavoir or 2 big plugs on sides? If the oring for resavoir is bad would it be normal for it to leak when pumping. It's definitely not the lines. Looks like it's coming from the back corner in-between the resavoir and pump.ill replace the oring for resavoir but wanna see if there's anywhere else I should check or orings i should buy. Part numbers would be appreciated also. And I have the correct cap already on the way.
tpenfield
Reservoir . . .
Nothing normal about a leak.
Is the pump over filled?
Put some paper towel below the line fittings to make sure it is not the fittings themselves - BTDT.
