trim pump oil
scott8058
So i checked the oil on my trim pump and its all milky white which i know means water in it. My question is where should i start to look for the problem and also what type of oil do i replace it with.....thanks
5.7 merc
alpha one gen 2
tpenfield
Re: trim pump oil
Start to look for the problem on the trim cylinders (outdrive) . . . Look for signs of leaks, etc.
Is there an oil sheen when the boat is in the water?
As far as replacing the oil . . . 2 options:
Quicksilver trim pump fluid
or
10w - 30 motor oil
are the 2 typical fluids called out in the mercruiser manuals.
Chris1956
Re: trim pump oil
I had the same issue. You can rebuild or replace the two trim cylinders, or cheap out and suck most of the oil out of the PTT reservoir and replace it periodically. I went the cheap out method.
