thedukeryan
- Joined
- Jul 21, 2009
- 298
I have a 75 mercury 850 with hydraulic trim. I went to purge the air out of the system thinking it may be the problem. Doing one at a tim I removed the bleed screws on the top and ran the pump till fluid sprayed out. Then I removed the cylinders and flipped them over and did the same with the other bleed screws. Put the screws in, filled the resevoir and ran the pump. Still got nothing. Would the next option be replacing the cylinders? I have another 850 that I was thinking about pulling the cylinders off and switching. Just don't wanna go that route if there are easier options out there.
