trim pump runs but no up or down
kinger952
pump runs in both directions -- up and down but nothing happens as far as raise or lower - never had this happen before possible sensors ? not sure - any suggestions on where to start looking going to try to bleed this am but dont think that will help ? could be wrong
tank1949
pull off rams, disconnect fluid lines and see if you can compress piston. Piston/ram may have locked up due to corrosion. I had to totally rebuild all 4 of mine.
kinger952
That just might be it.
I've took rams off unit and then bled system and not a thing. Now I'm going to pull end caps and see inside
QBhoy
Yeah. Take the hyd fittings off the end of the ram (carefully, they can suffer corrosion at the inserts into the Ally). See if you can move the rams and see if the pump pumps oil out them open ended. The pump may be relieving and returning to tank if the rams are solid.
kinger952
Took rams apart like new no corrosion !! Got a hold of a pump I'm thinking weak ? With lines off and hit pump juice pours out up and down so trying this
Drivewayboater2
While the cylinders are apart you may want to consider rebuilding. Inexpensive and a great sense of security knowing they are rebuilt. Just my 2 cents… hope you find the issue. Good luck
kinger952
That don't have a scratch inside and o-rings are like NEW !! I'll wait for that. Thanks
