I have a good boat with a 888. I dont have the 888 leg. I also have a rotted boat with an alpha 1 early 1st gen. I am going to use the outrdive from the alpha. Can i use the trim pump and rams from the alpha and then toss the reverse lockout? What should i do with the purple wire going to it? what is the purpose of that valve? The rubber bushings on the outdrive side wont fit in the 888 rams so can i just switch the whole ram to the alpha ones? The alpha boat is an 83 century and the 888 in a 73 hydrodyne.
