Hi there. My trim pump will only work for leg down. So far I have checked and confirmed that:
- the helm switch is good (new)
- the pump is good (can be jumped for both up and down)
- the relays are good (swapped them and still same problem)
I am left thinking that I must have a bad wire or connection in the harness. There are 7 wires coming from the switch that go into a round plastic plug (6 around the circle and one larger pin in the middle). The centre pin and one of the outer pins are of a larger gauge and were not hooked to anything (a black centre pin and blue/brown outer pin). At this point I am unable to see where the harness is hooked up at the transom, but I only have two wires going to the pump.
Do you have any suggestions how to proceed next? I was thinking of trying to locate a new harness if possible to replace this one. If I can figure out the connections at the transom. Any ideas? Thanks.
