Trim question for the new 150 HP SeaPro Outboard.
111torrance111
Trim question for the new 150 HP SeaPro Outboard, that I just purchased related to the tilt.
When tilted up all the way it hits the stainless Rod Holders and will scratch the cowling. I know some of the other brands (E-Tec's) have a setting to limit the travel, is there such a setting for this motor?
Jerry
QBhoy
Yea. There is a method of doing this. You need to unplug a couple of connectors under the cowling hood or something similar. Then re connect when you are at the maximum desired height. Have a search online about it. It’s something like that, you need to do.
Just found a link with instructions. Just double check before you do it. But pretty sure it’s the same method.
111torrance111
These orange wires discussed in this link doesn't exist on the new 2021/2022 Mercury motors, still looking for a solution.
Thanks/Jerry
