Woodbinekeith
- Joined
- Sep 1, 2009
- 86
Have a 1990 Merc 3 Cyl. 90 h.p. with Commander 2000 control that is new to me and I'm just learning. I have the thick service manual.
Hydraulic fluid is right up, and motor is up and braced in "trailer" position. Using the "up" and "down" before manually lifting it up resulted in the motor humming nicely but there is no lift in either the tilt or the trim.
There are four electrical connectors in a group just inside the cowling that come from the control. Two I have hooked to matching blue/white and green and white from the engine but the other two are not connected (doesn't seem to be anything handy to plug them into). It seems the brown/white is supposed to go to the trim sender and the tan one I don't know where it is supposed to go.
In reading the manual, I'm looking at the brown/white line that is supposed to go to the "trim sender. Since the brown/white line is not connected - what will be the result? Perhaps this is my problem. What exactly does the "trim sender" do when it is hooked properly. Better yet, what happens if the trim sender is not connected. Thanks in advance
