brandonw409
- Joined
- May 30, 2009
- 5
I have a 1980 johnson 115 (J115TLCSA). I thought one of the trim relays went out since it wouldn't go up but it would go down and the relay buzzed when the trim switch was pressed. Replaced both relays and still won't go up. Started moving the plug the relay goes into while my brother held down the trim up switch and it started going but the relay started smoking and smells like it might be burning up. So I assume there is something wrong in the wiring or the plug the relay goes into. I go to Johnson's website and look at the parts break down and the relay box doesn't look like what I have on my motor at all. The person that had the motor before me has screwed around with everything in there so I guess they switched out the old box and hard wired this one in there....I don't really know what I am looking at! also, in the parts break down there is an unpictured item called "junction box and cover". is this actually what I'm dealing with? And do I have to buy the whole freaking box to get the relay plug replaced? Thanks!
