dooma_Flatchy
- Joined
- May 18, 2007
- 289
Motor is an 1988 Evinrude 150 model number E150STLCCA.
The other day as I was loading my boat after a day of fishing I was sitting the motor on the transom saver and the motor wouldn't tilt down. It would go up but not down, I thought the transom switch was going bad so I tried with the throttle switch and then the bow switch and the same thing. The trim motor was working fine. I finally got the motor down by rocking the transom switch back and forth. I got home and checked the switches(3) and they checked out. I cleaned the contacts on the relays and I switched them around to check if one is bad and it's working perfect (so far). I'm going replace the relays when I get back to the lake but I just wanted a second opinion to make sure I'm thinking right.
