Trim reservoir filling
Taz59
With leg right down and reservoir cap removed,then fill to the top do you leave the filler cap off then try up and down a few times, or do you have to put the filler cap back on before you try to move up & down ?
Grub54891
Fill it not quite full, trim up and down a few times. It's a good idea to put a rag under the trim pump area before trimming. It's because if it was real low, it will foam up and look over-filled, some may come out. You will have to let it sit overnight at that point and check again in the morning. If the air is settled out it may look low, top off and repeat trim till its full and air free.
