phillnjack
- Joined
- Oct 22, 2003
- 51
hi guys i have a 1993 60hp merc with power trim. i cant seem to be able to find what trim sender kit i need for this engine. i have a kit part no 821400a2 but for this kit there should be a slot in the pin that holds the trim ram and 2 pre drilled and tapped holes for the sender to attach to. and i dont have any of these items.please help as i want to fit the trim sender, i have the guage, and the wiring is already on the loom tan with blue stripe,so with sender fitted ill be ok.everyone i ask seems to think this is right sender kit but it definatly dont fit mine without a lot of hassle.the stainless pin that holds the single ram has no pin running through centre but has pin on the side that holds in the staionary position.my engine serial no is 09707726 the tag says belgium if that helps at all. any info would be gratefull thanks in advance phill
