Trim sender/limiit switch
Streamer 71
Hello everyone and thanks again for past help. I have a 79 V-150 merc. #5342307. The out trim button will not work a have replaced sileniod and bridged the button and nothing. I have taken apart sender/limit switch and all appears well there. The trailer button works and I dont know where to go from here. The dealer tells me the sender/limit switch is no longer available. Any help would be great. Robert
Chris1956
Re: Trim sender/limiit switch
Robert, If the trim limit switch is bad and there are no replacements, you will need to learn to live without it. Put a jumper in the PTT wiring harness where the trim limit switch splices in. It should be two purple wires. This will allow the use of the trim up switch
