Horigan
- Joined
- Jun 12, 2016
- 691
First post...
I'm trying to remove the trim sender wiring from the transom on my '95 OMC Cobra SX. It looks like gasket sealant or something was used and I'm afraid if I pull on the wiring too hard I'll be left with just the rubber grommet in the transom passage. Yes, I removed the clip. Is there a trick to getting the rubber grommet out, other than trying to work a screw driver in to the hole from the engine side?
Thanks in advance.
Rich
Thanks in advance.
Rich
