Trim sensor issue, not already covered
skyviper
Hi, I have a 2004 Yamaha 115TLRC motor on my boat. I am looking for a replacement part for my tilt/trim sensor. Problem is that the part I need I can't find on any of the parts lists on the Yamaha website and I can't seem to find a name for it. I also can't get my camera in there to take a picture so I'll describe it the best I can.
On the rod that goes from one side of the assembly to the other there is a clamp with a small arm protruding off of it that the tilt/trim sensor meets with to make it rotate. That clamp is busted, I need a new one or at least some suggestions on what I can do to fix it so my gauges will show that my motor isn't always tilted up. I have called a couple different Yamaha parts dealers, I don't have anything close to me, and unfortunately they keep wanting to sell me the o-ring for the trim sensor which is not the part I need.
Thanks for your time,
Sky
skyviper
Re: Trim sensor issue, not already covered
Disregard, I finally found the part I'm looking for, I hope. It's the trim sender cam.
