Does anyone know how to adjust the trim sensor on a 5.0 V8 cobra. This is a 1988 four winns sundowner 215. Gauge works but isn't in the correct place where it should be. I see the arm that moves with tilt but what is the best way to adjust it? Is is the flat headed bolt?<br /><br />Also is there a arm that run from the choke to the carb? I put the original carb back on and replaced the choke but the other carb was wire wide opened. I am trying to figure out how this carb attaches to the choke? Anyone? Thanks Shane
