trim stuck in up
agaldamez
changed my impeller but while changing it my trim got stuck in up position. it will go run when i go up, but nothing happens when i press the down button.
getting voltage power is coming in. even tried a new solenoid, didn't fix it, took one i took out and replace it with the other and still same result.
the only thing i found was that i am getting no continuity from one of the wires going to the top solenoid from the trim control wire harness connector. i separated the harness and i get continuity from the other 2 wires but not the wire that goes tot he top solenoid.
do i need a new harness?
Don S
Re: trim stuck in up
What drive are we discussing here. Year may help, SN would be better.
agaldamez
so now i have swap the wires that control the up and down. so now when i press the up the motor goes down ( which now i can at least put the gear oil in and start the engine) but when i press the down button nothing happens.
i also am not getting any voltage to the original down wire when i press the down .
i am thinking it is the switch.
i have a new switch and the wire that goes with it. any one have any experience changing this switch out. i took the controller aprt and it doesn't seem very easy.
