Trim Switch Cover
flcusat
Well it's off and yes it did melt a bit, so I need another cover. Works fine will order another
I knoww this a very old thread but I'm looking for answers to this. Is this cover glued from the factory?
Yes the cover is glued on at the factory. I've used PVC high strength glue which worked, and when I had to remove again do to messing up, I used 2 part plastic epoxy. The reason I had to take mine apart the second time is because I put the new switch on the bottom instead of top (single motor)
