Trim Switch on the Outdrive part number?
Hondo65
I have an Alpha one outdrive. The trim indicator switch on the outdrive itself that sends the reading to the trim gauge needs to be fixed or replaced. None of my manuals show it or I haven't found it yet. Anyone know where I can find a part number?
I guess what I need is the sending unit
Thanks
Hondo
Don S
Re: Trim Switch on the Outdrive part number?
You basically have 2 choices. If the sender itself is bad, you can get a rotor kit for it. PN 805134A 4
If it's wires are gone too, they make a kit with the sender AND the trim limit switch. Both the newer style and new wires. PN 805320A03
Ayuh,....
Or you can just get used to it,+ drive by the seat of your pants........
You Do realize that the Whole Transom assembley has to be Totally torn down to install the New Kits,..??......
