sheboyganjohn
- Joined
- Aug 2, 2005
- 753
On the Sea Ray I removed the very old and butchered trim tabs from the boat and picked up a used set of Bennetts. When I looked at the install procedure, it showed a backer plate. Since mine did not come with a backer plate I decided the easiest thing to do would be to fab some up with stainless flat stock. When I test fitted it, the tabs bind on the backer plate. Can someone shoot a picture of the actual alignment of the backer plate and the hinge? Or are these backer plates more then just flat stock?
