Trim Tab Missing or supposed to be this way? '83 Mercruiser
egleas84
Looking at buying this Stingray and I noticed it doesn't have a trim tab like every other boat I've owned. Is it supposed to lack such a device?
ziggy
Re: Trim Tab Missing or supposed to be this way? '83 Mercruiser
if the boat has power steering. the tab isn't necessary. there should be a blank plate in it's place though that is a zinc for corrosion protection.
nice wale tale. po must think he ha problems with the way his boat performed.
Don S
It's possible the previous owner took it off so that prop would clear the fin. If that is the case, and you want a fin, you can either grind off part of a new fin to clear the prop, or get an outboard anode that has the setback built in.
