Trim Tabs
Sirocco
I have a 21ft Spectrum 650 power boat that is fitted with an OMC 140 4 cylinder petrol engine,<br />and an OMC model 400 outdrive. The boat is fitted with TX Control AB trim tabs controled by two bow up bow down switches on dash panel.<br />That is the limit of my knowledge of trim tabs, I recently took the boat out (the weather was calm)<br />and at a speed of 15knots with the trim tabs down<br />the wash behind the boat was horrific, no way could the boat plane, and the tabs seemed to act as a brake. The engine has a manual tilt and trim <br />which I am told can alter the level of the boat.<br />Can someone please advise the correct way to make the boat plane.<br />TX Controls produce a computerised control system<br />but I cannot find a stockist, if anyone can help <br />or suggest a unit that is compatable with the system and gives an indication as to the position of boths tabs at all times then please respond if <br />possible, or E-mail at DenisHl3@aol.com
crazy charlie
Re: Trim Tabs
I would start with the drive in the full down position and the tabs up.See what the boat does at that point when you give it the gun.If the bow goes straight up,wait a few moments to see if it begins to plane.If it does not then start to move the tabs to the down position a little at a time,just until it gets you over then hump and you begin to plane.You have to play with it to get the right combo of trim tabs and drive trim.Charlie
scamper
Re: Trim Tabs
After you get the right combo as Charlie suggests and you get on plane, your rpm’s should increase. As you add more power and pick up more speed, you should be able to retract the tabs and remain on plane. There will come a point where the taps will no longer be beneficial.
Tabman II
Re: Trim Tabs
Sirocco,<br /><br />I am Thomas and I work for Bennett Marine in the Client Service department.<br /><br />I have taken the liberty to provide a run down on how to get the most all of your trim tab system. Please read over it and let me know if you have any questions.<br /><br />I look forward to your reply.<br /><br />Sincerely,<br />MJ Thomas<br />Bennett Marine, Inc.<br />Client Services<br />trimtabs@earthlink.net<br />www.bennetttrimtabs.com<br /><br />Getting and Staying Trimmed <br />All boats assume different fore to aft attitudes at different throttle settings and vary in sensitivity to lateral weight distribution. <br /><br />A boat’s optimum running attitude is determined by the operator. While some people may define optimum running attitude as the highest possible speed for a given amount of engine RPMs, others desire the best possible fuel economy, yet others may be trimming the boat to get just the right mix of speed and wake (such as for waterskiing.) <br /><br />Optimum running attitude is when the boat is running to the operator’s satisfaction for the given operating conditions. There are as many optimum running attitudes as there are boats and boat owners <br /><br />A good way to determine a boats optimum running angle is to run the boat lightly loaded at full speed in calm water. During this test observe the boat’s bow in relation to the horizon. Most boats run at or near their optimum attitude under these conditions. This should give you a feel for the appearance of the wake and bow spray when running at an efficient attitude. Note that not all boats will achieve their optimum running attitude under these conditions. Some boats will benefit from extra lift even when running at their maximum throttle settings. If you feel the boat will benefit from added bow down trim when running at speed start with the trim tabs fully up and deflect the trim tabs in short bursts. Be alert to changes in the boats handling, as you bring the bow down. Observe any changes in RPMs and/or speed. Adjust power trim if applicable. <br /><br />Indications of Running Untrimmed<br />When a boat is running untrimmed the bow spray will exit the sides of the boat far aft. The stern wave (wake) is high and curling like a breaker on the beach. The rooster tail is high and close to the stern. The engine is laboring and the ride tends to be less smooth. <br /><br />Indications of Running Trimmed <br />The bow spray moves forward and is flung not as far from the boat. The wake diminishes in height, as the rooster tail flattens out and moves away from the boat. The engine is operating under less load as evidenced by the tachometer and speed as well as sounding “less strained”. <br /><br />One Step at a Time<br />The key to obtaining optimal results from trim tabs is to operate them in short “bursts” and let the boat react before making another adjustment. The amount of time between corrections is influenced by the size of the trim tabs and the boat’s speed. This will help avoid overtrimming or ending up with one tab too far down when correcting lateral trim. You will quickly become acquainted with a boat’s particular traits. <br /><br />Take Off <br />Properly sized trim tabs can significantly reduce the time needed to get up on plane. They also allow a boat to keep its bow down and stay on plane at lower speeds. <br />As the throttle is advanced the stern of the boat begins to squat, lifting the bow. As the boat accelerates, push the bow down position of the helm control in short bursts. The boat reacts by the stern lifting, the bow coming down, speed increasing, and reduced engine laboring. If you over do it and deflect the tabs too far the boat will end up overtrimmed. When over trimmed, the steering becomes “over sensitive” and wants to pull off course to port or starboard. If this occurs, operate the control “bow up" until the desired attitude is established. <br /><br />Getting the Most from Power Trim<br />Adjust the trim tabs to achieve the desired running attitude. Then use the power trim to position the propeller thrust parallel to the water flow. If necessary, re-adjust the trim tabs to fine tune the attitude. By observing the boat’s speed and engine RPMs the best combination of trim tabs and power trim will be apparent. Trim tab angle indicators and a power trim angle indicator are particularly useful in duplicating effective settings. <br /><br />Trimming to Sea Conditions<br />When running into a head sea you want to trim the bow down so the sharp forward sections of the boat do their work cleaving the waves. This provides the most comfortable ride and minimizes stress on the boat (and passengers). In a following sea the tabs should be fully retracted for maximum steering response. <br /><br />Correction of a List<br />As previously mentioned the normal control setup for trim tabs operates in relation to the desired changes in trim and not the actual movement of the tabs. Therefore, do not think about what the tabs are doing, but rather on the control and what you want the boat to do. As above, make the corrections in bursts and allow the boat to settle to the new settings. You may find it easier to correct the boat’s fore and aft attitude before you correct the athwartship trim. <br /><br />Correction of Porpoising<br />Operate the tabs in very short bursts of about half a second. Continue until porpoising subsides. The objective is to have only a very slight amount of tab deflection, just the amount needed to cure the up and down motion of the bow.
