Trim/Tilt 87 Johnson
Bluefish102000
1987 90 HP Johnson. Is there a specific proceedure for Draining & re-filling the Trim/tilt fluid with respect to the tilt arm position, check valves. ie. refill with tilt arm in down position...etc
rickdb1boat
Re: Trim/Tilt 87 Johnson
Not really. Just trim motor all the way UP and fill to the top. Replace screw and cycle it 4 or 5 times to purge the air. Check and refill as nessesary.
