DarthVader
- Joined
- Jan 28, 2016
- 88
Hello everyone,
I need some help again and it has to do with my trim/tilt gauge,I also having a issue with my trim/tilt when I am putting the motor down..
The first issue is my trim gauge does not work,I am not sure if it is the gauge or something else stopping the trim gauge from working,the first thing I check was the arm that has a spring on it just under the left side of my 1989 Evinrude 70hp to make sure it moves up and down freely and it does..
So I am not sure what I should check next to see if I can get the Trim Gauge to work,I always just turn my head to see where my Evinrude is position but it would be nice if I could get the Trim Gauge to work,so if anyone else knows what else I could check please let me know..
Now my next question,
I am not really sure how to describe this next problem so I hope that someone here can understand what I am trying to describe..
So my trim/tilt has been work fine since I bought my boat till I notice something different today about my trim/tilt,everything still works but when I go to put my motor down all the way I am hearing what I say is a rumbling/stuttering sound,I am think it maybe 1 of 2 things that maybe wrong.
One I am low on fluid or there is air built up in the oil tank.
So I checked the fluid and it did not come out the screw hole so I added just a little bit till it started coming out the screw hole, then I put the screw back in,so I check the trim/tilt again and it was still making that same weird rumbling/stuttering sound when putting the trim down..when I start hearing the rumbling/stuttering sound it is when it makes contact with the 2 piston rods that it touches when the motor is going down..
So is it possible that there is air that is causing this rumbling/stuttering sound and if so what is the best way to get the air out so my Evinrude is running smoothly again..
Thanks
Thanks
